skybox f5s intrucion manual
  • redsevern
    • Oct 2013
    hi guys just recieved my box i would like to hide adult channels from the kids is this possible also is there a good manual .
    what is a good snr on my info i am approx 75% who does that compare in the uk using standard sky dish
    apprecaite any help guys cheers red
    Why not just download one of the channel lists that do not have the Adult channels included such as from either AJ or sattv5
    • Panther785
      • Aug 2012
      • 79
      what Digicon has said, says it all tbh
      Panther
      • middots3
        • 194
        Install a channel list without the adult channels.
        And 75% is normal.
        • Hadron
          • 2102
          I don't know of a way to actually hide the channels in the list, but you can stop them from being viewed.
          To PIN protect Adult Channels.
          In menu, select System Setup > Parental Lock (default password = 0000).
          Set channel lock to ON.
          Select a new password & confirm with YES.
          In menu, select Edit Channel > channel edit.
          Press RED (group) button on remote.
          Select "Favorite".
          Select "Adult".
          Press GREEN (options) button on remote.
          Press OK to select ALL.
          Move cursor to selections on right hand side of screen.
          Scroll down to lock symbol.
          Press OK.
          A lock symbol will be shown next to all Adult channels.
          Press Exit.
          Confirm that you are sure to save.
          From now on, you will need to enter your PIN to view any Adult channel.
          • redsevern
            • Oct 2013
            thank you guys for the help much apprecaited is there a channel list you guys recomend and is it easy to install
            • Hadron
              • 2102
              My personal favourite is AJ's list, as I like the channel numbering. If you prefer $ly numbered channels, then sattv5's list is good. Both lists have a "no Adult channels" option.
              There are also a couple of other lists around which I haven't tried myself.
              Before installing a new channel list, you can delete your old one first. In the menu select Edit channel > Delete All. Select "yes" to confirm.
              After downloading & uncompressing the file, transfer the TP_PROG.dbs file to a memory stick & plug it into the box. In the menu, go to Tools > Upgrade by USB > Upgrade Mode = misc files. Scroll down to Select & Upgrade. Press OK. Press green (Add) button while TP_PROG.dbs is highlighted. Then press yellow button to upgrade.
              It should take around 10 seconds to upgrade. Press info button when finished to check that upgrade was successful.
              Put box into standby & back to ON.
              • redsevern
                • Oct 2013
                thanks next question what sever and where to stop pausing freezing its only slight but would like to remove
                  Cannot be Discussed: http://www.digital-kaos.co.uk/forums...rules-2/#post2 : Discussions about cardsharing are not allowed, including, but not limited to, cccam, gbox, mbox, etc.
