EXTRA BOX UPSTAIRS *help needed*
This topic is closed.
  • deano8899
    • Jan 2013
    • 4
    Hi guys
    Can you run more than one box off the same ccam server?
    Also if my dish has one LNB output is it just a case of adding the extra LNB or is a new dish required if I were to run another wire from the dish to an extra box upstairs.
    I currently have a sky F3s box.
    Cheers in advance
  • P&D
    • 2686
    Answer to the 1st question NO...not with out permission
    A re-fresh of the rules might be in order regarding the 1st question (line 6 of the rules)
    2.if you have the $ly dish are you sure it only has 1 connection on the lnb (normally 4) most times.....if only one cable out put then yes a new lnb is needed
    yes you will need 2 feeds one to the upstairs & one down stairs
    Lnb about a tenner for a cheap one ?15-20 for a good one
