is there anyway to get rid of the skybox logo on start up off box
old openbox/skybox s10 you could use mst firmware tool.
newer receivers you are sol
Have you ever used this tool yourself for anything other than replacing logos?
I was wondering what use the other options are such as extracting & importing block/data from different parts of the image.
I was interested because I've tried out many images for my old S9 & S10 & finally found one that I like C2DS2_CMT_120620044F (= C2HS2-12-06-18:05E3CMT). The only niggle is that there is no option to dump the "see see c a m.cfg" file in the "dump misc files" menu. I was wondering where this bit of code might be in the image & whether it may be in one of the blocks that can be perhaps swapped with that from another image?
This firmware is also the only one I have come across that doesn't show a boot logo (just a plain blue screen).
