F5S - what causes flickering?
  • gneville
    • Nov 2013
    • 6
    Might be an obvious answer to this - but what causes flickering / stuttering? BBC HD and ITV HD are pretty bad every 20-30 seconds or so.
  • P&D
    • 2686
    The part you add to your box for tv
    Is Shit mate..............9/10
    before you ask sorry we cannot help you to get a better one........
    • sattv5
      • May 2013
      • 376
      Seen as though you are on FTA Channels then freezing and stuttering should not be happening.
      Are you using a HDMI Cable ?, if so try changing it.
      • P&D
        • 2686
        never notice the channels ....might be the firmware ....whats running on the box at the moment
        menu/system info
        • intel
          • Apr 2010
          • 128
          When on BBC One, press the INFO button and check what the signal level is? these are FTA channels so it would make no difference even
          if you did or didn't have a gift installed, the FTA channels should still all work 100%
          • fawada123
            • Oct 2013
            • 8
            HI, try v-format on your remote, use 720p_50 Htz that might help. this box is a piece of S*** but we might learn more as we go along.. hope that helps (let me know)
