problem with new f5s?????
  • fryz77
    • Jun 2013
    • 19
    hi,im having problems with a new f5s box,itw worked fine for a few weeks but now i cant get any picure at all and only get the no signal message on every channel? also the little green light on the front display isnt showing like it used to.ive checked my sattelite cables etc,any ideas? thanks guys
  • R7UST
    • Oct 2013
    • 15
    Hi.
    Have you checked that your power adapter is working,
    switch it off at the wall & make sure it's plugged into the box & you don't have a loose connection.
    Worth a try to see if the box turns back on.
    • titty
      • Mar 2009
      • 16
      try a scart see if it works
      • kpts5
        • Sep 2013
        • 28
        hi check satellite dish cable or connection. no signal means form dish.
        • fawada123
          • Oct 2013
          • 8
          Hi fryz77 your LNB is on its way out or already dead was it an universal one? you have to use a "no signal fault fix" from ebay.
          If you have a message saying No Signal on some channels, usually S**Sports 3, E**N, and HD movies like Action HD, Comedy HD, Disney HD, Family HD, Greats HD, Modern Greats HD, Premier HD and SciFi/Horror HD among others but most other channels are fine, then you are most likely using a universal or quad LNB on your dish
          These LNB`s operate at around 13 volt`s for channels with a vertical frequency and around 18 volt`s for channels with a horizontal frequency
          Some satellite receivers operate at a higher voltage and cannot switch between vertical and horizontal frequencies.
          When you install our No Signal Fix the voltage is reduced to a level that your receiver will operate normally and allow viewing of both vertical and horizontal frequencies
          hope that helps.. you might be too late if you are not getting a green light...
          • fryz77
            • Jun 2013
            • 19
            tried all of these including the no signal fix but its on all channels and the lnb is fine because its working another skybox at the house.its the no green light bit thats baffling me?
            • kpts5
              • Sep 2013
              • 28
              if you using 2 box in house same line then its happend no signal in few channel. so you take wire from LNB for both box then solve your problem because in my house 2 tv when i switch off 1 box other is ok so i extended 2 wire from LNB to 2 tv because my LNB have 4 out .
              • fryz77
                • Jun 2013
                • 19
                no its one f5s box only ever used
                • P&D
                  • 2686
                  Disconnect all the cables apart from the power lead
                  see if it boots up
                  If not then its a power problem....box or power adapter
