I have an F3 and want to know how I import a new TP List to the box. When I delete all channels it deletes the faves and everything, completely removes them from the box but in my menu under the TP List loads of TP are still listed. I Believe this list needs updating maybe with a .ini downloaded from say here satellites.xml generator / transponder .ini generator as I cant get bio anymore not even with AJ's latest temp channel list. So does anyone know how we update the TP list of the box as I am sure some are out of date as at least 3 say FAILED when doing a scan. at least that's how it worked when I had my DM7025 it was separate TP and channel lists or does the F3 work different. A tutorial on how TP Lists on the F3 work would be a nice addition to this site as I am used to DM Boxes
SkyBox F3 TP List questions
I dont think there is a Bio channel now.I have an F3 and want to know how I import a new TP List to the box. When I delete all channels it deletes the faves and everything, completely removes them from the box but in my menu under the TP List loads of TP are still listed. I Believe this list needs updating maybe with a .ini downloaded from say here satellites.xml generator / transponder .ini generator as I cant get bio anymore not even with AJ's latest temp channel list. So does anyone know how we update the TP list of the box as I am sure some are out of date as at least 3 say FAILED when doing a scan. at least that's how it worked when I had my DM7025 it was separate TP and channel lists or does the F3 work different. A tutorial on how TP Lists on the F3 work would be a nice addition to this site as I am used to DM Boxes
Any TP you are missing can be added manually and then scanned.
Menu
Installation
TP List
Add (Green Button) -
You don't have to import TP lists, you simply do a blind or accurate scan to populate the TP list.
As the name implies, you should pick up all active transponders during a blind/accurate scan, plus any that were saved in the TP list before they stopped being used. So you may have some that will say "failed".
Bio (UK) stopped broadcasting on 4th November.
http://en.wikipedia.org/wiki/Bio._(UK)Comment
