ive got a few universal remotes but cant seem to get them to work the skybox f5. anyone know the 3 digit and 4 digit codes i can use to get them to work
universal remote code for skybox f5
i emailed one for all and they have sent me the code of the box and a remote update, i have a Kameleon 6 one for all and it now works everything on the skybox f5. they also sent me a file to update my remote which i did. here is a copy of a bit of the email they sent me about the code, hope it helps someone.
Please find attached a WAV file with the following code to try :
SAT 3109 ( to setup as 1109 on SAT)
If one of your codes are above 2047, please read the following information:
(In this explanation we will use code 2049 as an example.) If you require a download for code 2049 it will be downloaded as 1049 and will need to be entered into the One for All as 1049 but when you require additional functions or another upgrade you will need to mention 2049 so we are able to give you the correct code.Comment
