Can't connect via ethernet cable with Skybox F3 ?
  • satvfan
    • Oct 2012
    • 8
    Although I am 'connected' in network setting I can not connect to anything. Do I have DHCP on or not ? Either way I can not connect to upgrade or youtube etc
    Also the firmware I have is 3601HD_01-05-2013_0951
    Is this the latest ?
    Any help much appreciated
  • P&D
    • 2686
    After connecting the ethernet cable have you re-booted the router ??
    • genam
      • Apr 2013
      • 176
      DHCP needs to be on unless you want to assign a fixed IP address.
      Upgrading these boxes is via USB .
      Firmware...latest official is 28-3-13SkyBox | SkyBox
      • DW190
        • May 2012
        • 1263
        On unless you want to enter a static IP manually.
        • satvfan
          • Oct 2012
          • 8
          OK thanks, what is the update for and will it wipe out my sat info ?
          Yes a reboot of the router fixed things sort of
