skybox f5s wifi , working well but doesn't stay active after a reboot?
  • stevenfrenchy
    • Jan 2013
    • 36
    hi there
    got the wifi dongle working well but if i switch off the receiver and then switch it back on ,i have to activate it again ( it does remember the password though )
    is it the case for everyone ?
    is there a way for the box to remember to connect to the wifi?
  • stevenfrenchy
    • Jan 2013
    • 36
    Anyone at all please ??????
    • remu
      • Feb 2013
      • 5
      I HAVE SAME PROBLEM WHEN USING DISEQC 1.2 POSITION ON FEW SATELLITES BUT WHEN "DISABLED DISEQC 1.2" AND USING ONLY "ONE SATELLITE" WIFI WORKS PERFECTLY AFTER REBOOT.
      IF U USE ONE SATELIT GET LATEST FIRMWERE FOR BOX AND WIFI WILL WORK PERFECTLY BUT WITH DISEQC 1.2 ENABLED THEN AFTER REBOOT WIFI WILL BE DISABLED ...
      • stevenfrenchy
        • Jan 2013
        • 36
        Hi thanks for the reply
        I do use a motor usals set up
        I will disable it and give it a try
        I thought it would a software issue , why would the Motor be an issue with wifi ? Processor not working hard enough :-) ?
        • stevenfrenchy
          • Jan 2013
          • 36
          You're right it works !!
          Weird they cannot make it work with motorised dish !!!
          Thanks mate
          • stevenfrenchy
            • Jan 2013
            • 36
            Thanks again for that !
            I just bought an openbox x5 off eBay ,
            It has 2 usb so can record and wifi in same time (usb splitter not work on f5s) , hopefully the memory channel will be higher than skybox f5s as after 3 or 4 satellites search I'm already full :-(
            • remu
              • Feb 2013
              • 5
              It looks like PSU in the box is crappie and can't handle motor and usb wifi output together. ...
              • kaiser28
                • Oct 2012
                • 4
                Guys,
                I seem to have the same problem above, has anyone been able to solve this issue, my brother has a skybox f5s with motorised dish, on starting wifi is always not active, has to activate it all the time.
                Cheers
