hi, can anyone point me in the right direction, I have a sky box f5 and I have lost some of the channels of it, I don't know a lot about uploading new channel list to it and would like some help doing this from start to finish, firstly where would I obtain an up to date channel list in the correct order, am I better off updating the whole list or just the channels I have lost? if anyone can help me or point me to the correct thread it would be very much appreciated
sky box f5 channel list update
Just stick AJ's list on. Its quite a simple job as long as you have a zip extraction program like winrar, winzip or 7zip.hi, can anyone point me in the right direction, I have a sky box f5 and I have lost some of the channels of it, I don't know a lot about uploading new channel list to it and would like some help doing this from start to finish, firstly where would I obtain an up to date channel list in the correct order, am I better off updating the whole list or just the channels I have lost? if anyone can help me or point me to the correct thread it would be very much appreciated
Save the TP_PROG file to memory stick or desktop then copy to mem stick.
Box on any channel.
Plug USB memory into box
On your Remote Control:
Press Menu
Right or left arrow to Tools
Press OK
Scroll down to Upgrade by USB
Press OK
The Top Line needs to be changed to Misc Files by using right or left arrow
Then scroll Down to Select & Upgrade
Press OK
TP_PROG.dbs should be highlighted
Press OK (Places a tick at the end)
Press Yellow Button.
When finsished (100%) Press Exit, Exit,Exit
Remove USB
Box may reboot itself but if not power off and back on
Hi DW190. Thanks for your reply, it looks quite straight forwards, can you tell me which list to down load with no adult content, there seems to be 2 of them without it? I have down loaded winzip, when I down load the correct list do I down load it to winzip and then on to my usb device? thanks for your helpComment
One of the files will contain duplicates of HD Film & Sports channels in SD as well (with SD), while the other one will not.Hi DW190. Thanks for your reply, it looks quite straight forwards, can you tell me which list to down load with no adult content, there seems to be 2 of them without it? I have down loaded winzip, when I down load the correct list do I down load it to winzip and then on to my usb device? thanks for your help
Once you have installed Winzip it should provide you with a right-click context menu. So when you download AJ's channel list, just right-click on it & select "extract here" or "extract to" or something worded similar. Once it's uncompressed just copy & paste to your memory stick.
If you prefer a Sky ordered list (same as you would get on a subbed Sky+ box), then download the channel list by sattv5.Comment
I've downloaded the channel list, put it onto a USB, plugged it into my F5 and updated but it comes up with;
Upgrade None!
Any ideas what im doing wrong?Comment
Are you selecting the right file on the upgrade file option and if the channel list file isn't named correctly it won't load!!
Do as dw said and Download aj's list extract the file and then put it on usb stick then load into skybox
Sent from my ThL W5 using TapatalkComment
Ive wrote on somewhere else ive lost ch 5 hd and normal ch 5 and all box office channels are in someones fav list? Since i last updated think it was the 3rd dec ive got a f5s box. Think there must be another update due soon for the channel list. Well hope so mrs always watches ch 5
can anyone send me a link to the channel list ,i cant find it no were, i have a f5 skybox hd. many thanksComment
Hi all, quick question. I have a Skybox f5 (clone) i downloaded the firmware update from: www.hddvbsw.com
i would like a channel list for sky channels to be in some form of order. my worry is using a wrong channel list and bricking my box.
can anyone suggest a update i can use?Comment
