channels not updating when upload TBS
  • Dan321
    • 12
    Hi
    I have followed the instructions to upload the TBS file onto my box, and for some reason after restart there are only a few channels like BBC channels, and nothing else.
    Also favourite channels says " Favourite group 21" or something with no channels inside.
    EDIT I mean DBS file.
    What am I doing wrong?
    I have also tried deleting all the channels and doing it that way.
  • Nobby Nutz
    • Apr 2012
    • 191
    What Box have you got as had the same issue with Favourites on a S11 and a F3S and the below worked a treat on AJ's List.
    Instructions taken from Sattv5 Stickie
    "The way to get The favourites under the correct headings is to load the default Database:
    On the remote select Menu > Factory Settings > Select Yes > Then Press Blue (Don't make any choices at the menu)
    The screen will flash black and you will be back at the menu. If you check your favourites now they should all be in the correct order"
    Don't forget to take a Backup first just in case.
