f3 ox loads channels freezing and then scrambled?
  • singh1234
    • Aug 2009
    • 156
    hi i updated with ajs 3/12/13 list and most of my channels are freezing loads and then shows as scrambled,some channels dnt work like channel 5?
  • souldude
    • Jun 2011
    • 37
    If your channel 5 not working then you have not uploaded the channel list correctly, as the new list has channel 5 working as well as others.
    re download the channel list and try again .
    • mickyd123
      • Aug 2013
      • 35
      Probs a bad file as said redownload the file remember to extract the file to root of memory card. Suprised how oftern people dont, delete all in frav list then do the channel list upgrade
      • singh1234
        • Aug 2009
        • 156
        hi what do u mean extract to root of memory card how I do that. I downloaded new list,deleted old channels then upgraded as normal,but still not working?
        • P&D
          • 2686
          Hi if its just channel 5 missing try this...http://www.digital-kaos.co.uk/forums...ewbies-356919/
          • portvalefanjosh
            • Dec 2013
            • 101
            Mine isnt and ive even done the how too fix missing channels. So you are wrong with that comment. 9 of my friends also have the same problem, its the update that caused the problem. Not us not knowing what we are doing.
            • crude
              • Oct 2013
              • 34
              Do any other channel listings work?
              • portvalefanjosh
                • Dec 2013
                • 101
                As ive stated else where its ch 5hd not working ch5 has been removed and all the box office channels have been moved into someones made up fav list. Ive checked all over the net and there all lots of people having the same problem, not just us, so i would guess aj will be trying to do a new channel list as we speak.
                • portvalefanjosh
                  • Dec 2013
                  • 101
                  No not atm. All the same.
                  • crude
                    • Oct 2013
                    • 34
                    I meant other than AJs
                    • portvalefanjosh
                      • Dec 2013
                      • 101
                      Just tried downloading all of ajs channel list from 3rd november till the last one on the 3rd of decmber and i think thats works, you have to do each one at a time. But will update as all of mine have just scammbled.
                      • singh1234
                        • Aug 2009
                        • 156
                        I have noticed the sd channels are kinda fine just bit of freezing,but most hd channels are not working shows as scrambled,anybody with same problem?
                        • portvalefanjosh
                          • Dec 2013
                          • 101
                          Just too say the ch 5 hd signal is back so looks like that doing what i did fix the problem. But dont forget you have to do them in order too work.
                          • singh1234
                            • Aug 2009
                            • 156
                            is ur bt sports working fine? I noticed majority hd channels are not working? so what did u do mate what shall I do?
                            • southpaw
                              • 2233
                              I don't think it was down to that mate, each update over writes the last so your method makes no sense, just upload the latest list, no need to back track and do them in any order,
