New Official Skybox F5S/F3S Software Released 24/12/13
hiya ive done the update works great 1 question do I need to leave the usb stick in for the epg are can I remove it and will the epg still work thanksComment
Vu+ Duo-BH 2.0.9,1
CloudIbox II+
DM600PVR & DM500
Skybox F5 & F5s
Oscam 9533 & CCcam 2.2.1
0.8/ 4.8/ 7.0/ 13.0/ 16.0/ 19.2/ 23,5/ 28,2
ScandinavianComment
A new software has just been released for your F5 box which I have added in this thread:
Hi guys have just installed new software release and aj's channel list, the following print out was attached to the file saying how to setup the new epg setup " SKYBOX F3S F5S 131217 NEW EPG
1.Support view XMLTV by Box's cahnnel.
a.Goto "System Setup", enter the "EPG And Time Setting" Menu,
Set the EPG Default Setting as "XMLTV".
b.In the "XMLTV EPG" menu,Press red key to downlaod the data
manually.If switch "Auto update" on , the box will download
the epg data in standby mode Automatically(Panel show "EPg-").
2 .New "OK list" to switch channel more easily.
a. Press the left or right key to switch between "OK list" and
"EPG Window".
b.For the old "OK list", goto "Micro Panel" Select the "GUI Config" to swtich .
upload/20131218013841910.rar ==== Have tried to follow these instructions and am struggling. Any help would be great guys. Or Should I just ignore this.
Hope it's ok to post this guys.
@wally6529
The " EPG and Time Setting " should already be at the default setting once you update the firmware but the first time you use it you will need to enter the Network menu of your box, then go to Network Apps, enter XML EPG app, highlight the UK and then press the red button to download the EPG for the UK. Also, while in this setting, using the left/right arrows of your remote you can also set the EPG to update automatically. You must of course have a USB stick or Hard Drive connected at all times for the EPG feature to download and continue to work.Comment
