Bought myself a Skybox F5S - only going to use it every now and again and going to use an original SKY+ HD box most of the time. I've only got two LNB outputs coming down from the dish and I don't want to add another - what I'd rather have is a way to switch the LNB output from my SKY+ HD box to my Skybox. I'm only going to be using one or the other - not both at the same time - so rather than disconnect the LNB wire and plug it in each time, is there a way I could get a switch box which would take my LNB input, and bring out two LNB outputs that I could switch between - i.e. a box that lets you output either to wire A or wire B.
If that's not going to happen - is there any other method to easily be able to switch between the two?
Thanks - sorry if I've asked any stupid questions - new to all this.
