Hi there,
I have Skybox F5s and i am using AJ's current channel list from his updated thread. However i am having an issue with Life OK channel. The channel has intermittent problem i.e comes on for a bit than goes back to "scrambled"(repeat). I don't know what is causing the issue because other channels are fine.
Ive checked my internet connection and it appears to be fine. I have tried the following but it didn't solve the issue:
My gift provider keeps saying check your setup but what should i be exactly checking when all the other channels work fine.
I will try updating the box with latest firmware if that makes any difference.
I would appreciate if you could provide me with other suggestions i can try.
Cheers,
- Delete the channels
- Reboot Box
- Apply the Channel list
- Reboot Box
- Turn box off
- Unplug main power cable from Box
- Plug mains power cable into box
- Turn it back on
Cheers,
