USB Hardrive constantly Disconnecting amd connecting openbox s11
  • Adam7862
    • Apr 2012
    • 42
    Hi ive had my openbox s11 for over 2 years and although I used to get the odd "device speed is too slow" error the box would carry on recording, however recently my box died and I recovered it with a different firmware and now with the same portable usb hardrive every few seconds I keep getting usb disconnected and usb connected, as a result recordings are impossible. Is this firmware related or does the hardrive need replacing, im just curious as it worked fine before?
  • genam
    • Apr 2013
    • 176
    sounds like the box can't power the USB drive properly...if you have a HDD with its own power pack try that to eliminate the USB signal side of things.
    Have you had the HDD checked in a PC to see if its OK and to prove the cable....often the supplied cables are crap and a better one sorts issues like these.
