install new sw on f5s
  • jc69817
    • 138
    hi guys im having trouble getting my head round installing the new software on my F5s. Could someone please give me an idiots guide to installing this. Many Thanks
  • Sshhh4
    • Oct 2013
    • 16
    This is from bigade1's thread so credit goes to him, it helped me with the upgrade:
    As always, first back up your original files before performing a software update. Using a USB stick that has been formatted to FAT32, enter the " Dump By USB " menu of your Skybox and first select the Image file ( which is your software backup ) and dump to the usb. Then change the image setting to miscellaneous files and select TP_PROG.dbs ( your channel list ) and CCcam.cfg ( your gift provider ) and dump these also. Make sure that you place a tick in each file you are dumping to usb by either selecting OK or the yellow button on your remote. Copy these files to a safe place on your PC. To upgrade, download the new software and extract it using the appropriate programme e.g. Winrar etc., then copy it to your usb stick. Once inserted, navigate to the " Upgrade By USB " menu option, select the image file, making sure it is ticked, do not alter any other settings and select upgrade. Wait for the upgrade process to finish and the box should reboot. If it does not reboot do it manually by powering off then on using the remote.
    • SpiKed
      • Feb 2013
      • 55
      Download the .rar file..
      Unzip file to recieve .abs file
      Put .abs file onto a USB stick
      Put USB stick into Skybox f5s
      Press Menu on the remote.
      Press Down (The menu is called "Tools")
      Press OK
      Go down to upgrade files by USB, Press OK
      Upgrade mode should already be set to "image file .abs" So go down to Start and press OK.
      Shh beat me to it, that will teach me not to refresh first
      3x Skybox F5S 1x VU+ Duo
      • jc69817
        • 138
        thanks guys. Spineh that makes sense. sshhh4 that is the post that I couldn't get my head round ;-)
        • P&D
          • 2686
          Why are you installing a new firmware ????
          • jc69817
            • 138
            for the epg.
            • jc69817
              • 138
              Hi guys. Im still having trouble with this. I don't seem to be able to unrar the file. Could somebody please email the un-rared file please. Thanks guys
              • braddz
                • Sep 2013
                • 18
                hi when you have put the usb back. into your skybox do you have to put any thing back on it that u have just dumped?ie the channel list/sub?
                • bobhope1
                  • Nov 2010
                  • 85
                  check your PM
                  • Nobby Nutz
                    • Apr 2012
                    • 191
                    Hi you will need to Upload TP_Prog (Channel List) and ???am.cfg File after uploading ABS File.
