Skybox F5s Channel List Hotbird 13 & Astra 19.2
  • kaiser28
    • Oct 2012
    • 4
    Hi Guys,I had sometime to fiddle around in creating a channel list for the f5s. It is set up with hotbird 13.0 and Astra 19.2. Everything is ordered by name and I tried to remove all the duplicates.I wished to share this with you guys in case anyone uses the above mentioned satellites as I do.
    The channel list has favourites set up as follows:
    Hotbird
    Sky Italy
    Cyfra+
    Cyfrowy Polsat
    RAI
    Eurosport
    NC+
    Astra
    Can+
    Sky Germany
    Bein
    CanDigitaal
    Can Sat
    OR
    F
    If anyone has any suggestions for adding any other packages in either sat let me know and I would be happy to edit and share again.
    Always backup before use.
    Cheers
  • tzac29
    Excellent job.
    It will be very nice if someone can make a list with fav list like in dreambox enigma2 e.g. SportHD, Sport, FilmHD, Film, FreeHD, Free, NatureHD, Nature, Music, News etc. and then sort in alphabetical order
    • chrismalta
      • Oct 2013
      would you be so helpfull to explain how you did it?? please for hotbird and astra
      Hotbird
      Sky Italy
      Cyfra+
      Cyfrowy Polsat
      RAI
      Eurosport
      NC+
      Astra
      Can+
      Sky Germany
      Bein
      CanDigitaal
      Can Sat
      OR
      F
      Cheers
      • stavros67
        • May 2013
        • 81
        Astra 28.2
        • chrismalta
          • Oct 2013
          Astra 19.2
          Hotbird
          Sky Italy
          Cyfra+
          Cyfrowy Polsat
          RAI
          Eurosport
          NC+
          Astra
          Can+
          Sky Germany
          Bein
          CanDigitaal
          Can Sat
          OR
          F
          Cheers
          Originally posted by stavros67
          Astra 28.2
          • Kevin2k1
            • Apr 2014
            THX...do u have a newer list? And with which editor do u do the list?
            • AfyB
              • 144
              And maybe one with 28.2E also included, that would be much appreciated, only one I could find was on Ebay
              • P&D
                • 2686
                Right under your nose mate (in the red stickys)
                Sattv5 made an how to
                Here's the link How to create a channel list for Openbox/Skybox S9, S10, S11, S12, M3, X3,F3, F4 & F5
                • P&D
                  • 2686
                  With a channel editor like this How to create a channel list for Openbox/Skybox S9, S10, S11, S12, M3, X3,F3, F4 & F5
                  or scan the sat's you want then dump the TP_PROG file from the box
                  Menu/Dump by usb/misc files/ choose TP_prog/press ok/press the yellow button
                  to do this you need a dish that moves or multi lnb setup (if your dish is fixed then you cannot use the channel list for what its intended for)
                  • Ssenyonga
                    • Jun 2014
                    what would be the use of the attached files
                    • Hadron
                      • 2102
                      It's a channel list for 13e & 19.2e satellites.
                      • tommie
                        • Oct 2011
                        • 18
                        Hi guys,
                        Does this include a complete scan of Hotbird or just the favourites listed on first post?
                        I`m after the polish C****+ in particular
                          Originally posted by tommie
                          Hi guys,
                          They are listed in the First Post as Cyfra+ also known as NC+ and Polsat run identical channels
