skybox f5s no signal
  • johnt42
    • Dec 2010
    • 6
    hi guys, was wondering if anyone can help. I have a skybox f5s and when I scan i get no channels it comes up with nothing just says no signal just wondered if this means the box is dead, tried putting new channel list on but still no signal.Originally took the coax out to try another box and when I put it back again ...nothing, dish is ok because my dreambox scans and receives channels. If anyone can help I would be most grateful.
    Thanks John T
    DUFC.....JOHN T.....FTD83
  • bijan
    • 58
    Could be the firmware I think what's on it at the moment?
    • johnt42
      • Dec 2010
      • 6
      im not sure mate theres a robot type guy when you bring up the menu, please excuse the ignorance new to all this, where would I find firmware details
      • bijan
        • 58
        Try this mate
        • johnt42
          • Dec 2010
          • 6
          thanks bud will give it a go tomorrow. Thank you
          • djax
            • 6
            One of mine did that not too long ago, and apparently it was something to do with the power board on mine, you could try flashing it with the r32, sometimes they just need re flashing.
            • Hadron
              • 2102
              I know this may sound silly, but it's easily done. When you reconnected the LNB cable, did you put it back in the "LNB IN" socket & not the LOOP socket?
              The LNB IN socket is the second one from the end.
              Also have you checked that LNB Power is set to ON in the Installation menu & that in the Antenna setup menu, the LNB freq is set to Universal (9750-10600), & that both DiSEqC options are set to disable.
              • johnt42
                • Dec 2010
                • 6
                argh feel like a proper diddy put the cable into the LNB in and wallah channels back. Had it in the loop socket, only thing is that all free ch are back all other channels are scrambled think might have done something wrong while trying to get channels back. Is there any way I can check settings have not been deleted.
                Thank you all for your help
                John T (diddyman)
                • johnt42
                  • Dec 2010
                  • 6
                  hi guys thanks for your help all back to normal seemed to be a network problem once back on, just had a nosy through everything and noticed network setting on GPRS and not Ethernet, must learn to leave things alone.
                  Thank You for your help
                  John T
