SIGNAL QUALITY
  • jckw
    • 760
    SIGNAL QUALITY
    HI ALL CAN ANYONE TELL ME IF THIS WILL AFFECT MY GLITCHING ISSUES MY SIGNAL INTESITY IS 85% BUT SIGNAL QUALITY IS FLICKERING BETWEEN 70 AND 72% ON SKY CHANNELS
    we are all learning each day
  • Passive
    • Jul 2011
    • 30
    Various boxes will give slightly different strength / quality results, but your readings are much the same as mine on an Openbox X3. No problems with glitching here.
    • jckw
      • 760
      on bbc 1, 2 its 85% and 85% but on sky sports it drops to 72% so it scrambles
      • LoCkeh
        • Aug 2013
        Signal of 73% for Sports is normal and will not cause scrambling, that is down to your line provider or poor internet.
        • Passive
          • Jul 2011
          • 30
          Same readings here on BBC1. Don't think your 'quality' readings are the problem, as I'm sure I've had much lower readings during bad weather (around 50 percent or less) and still no glitching.
          • jacquesy90
            • Dec 2013
            • 92
            Same here, most my channels are at around 70% and completely glitch free.
              I had similar problem, make shore your input cable from disk is good tight fitting a bit loose and will cause glitch.
              • jckw
                • 760
                checked line in and its ok internet feed is good box keeps turning its self of and looses signal do you think it could be firmware issue
                • jacquesy90
                  • Dec 2013
                  • 92
                  Sounds like it could be firmware, either that or a dodgy box. Have you not tried resetting to factory settings and doing a fresh firmware update? Dump everything to usb first of course and see if that works
                  • Passive
                    • Jul 2011
                    • 30
                    could be firmware, or even power supply problems. If you post the actual make / model of box, someone may be able to narrow the possible cause down for you.
                    • lescombes
                      • Dec 2013
                      • 13
                      On a 60 cm round dish in East Anglia... HD channels on both Astra 28 & 19.2 .... all 85% & Non HD 76% with a 3% fall in signal during the rain we have just had on the 19.2 bird only
                      Getting a Signal Intensity of 90%
                      • Frogger
                        • Oct 2012
                        • 422
                        Had spethng similar and moved the LNB a bit. It fixed it.
                        If yours doesnt fix it... You could.
                        Reflash with the correct firmware. Get the ID of the current firmware on the box from the menu, information area and CRC it. (Cross Reference Check)
                        U could factory default the box, select nothing to delete, IE cccam-Smartcard info, press the blue button for OK, but make sure you do a USB dump-bakup first though..
                        How many "sealions" are alive on the box at one time?
