SKY box F5s all set up installed dish on outside wall. Box is fine when not plugged in to satellite with coax wire. When plugged in to satellite constantly spins on load.
Got a digital sat finder it isnt powering up at all. Using an F connecter to F Connector from dish to sat finder plugged in the correct side Anyways went by the neighbors dish and had it almost accurate bar a few degrees for south east for Astra by checking with a compass but couldn't get an elevation of 20 degrees above the horizon plus I think there was something blocking the signal maybe the fence
to the LNB so I am gonna move it up the wall tonight hoping that works.
Could this be the only reason that the box is spinning on load while hooked up to Satellite as when a turn the box off take that out and put it back on the box loads up no bother. So could it be cause a signal isn't currently being received?
Box works no bother when plugged in to my dish.
to the LNB so I am gonna move it up the wall tonight hoping that works.Could this be the only reason that the box is spinning on load while hooked up to Satellite as when a turn the box off take that out and put it back on the box loads up no bother. So could it be cause a signal isn't currently being received?
