Skybox F5s. "No signal".
  • bottleandahalf
    • Nov 2013
    • 20
    Hello everyone. I am getting the "No signal" message on a lot of channels including bbc, ITV etc. I have tried all the usual - Channel update, satellite scan. Tried box on 2 different dishes but I am still getting this message on a lot of the channels.
    I have tried factory reset, new firmware but still getting the "No signal" message.
    Anybody have any idea what is up with the box and can it be fixed?
    Thank you
  • mickyd123
    • Aug 2013
    • 35
    seen this discussed befor and it says check dish alignment and lnb in case is gone or by a no signal fix off the popular auction site
    • bottleandahalf
      • Nov 2013
      • 20
      My other F5s is working with it though. No signal fix won't work as it's not a polarity problem though
      • P&D
        • 2686
        sounds like a dead box if you have tried it on a different setup & its still the same
        • yasminandrio
          • 1256
          I've had a problem like this before I bought a number of these boxe from somewhere and two of them had a problem with the tuner or the connection you put the coaxial cable in! What I did was make sure it was the only thing connected to th dish/lnb also the copper wire in the middle of the cable I made very large and it seemed to sort out problem. I just think cause the boxes are mass produced you do get the odd faulty one.
