skybox f5s
  • dojopros
    • Nov 2012
    • 4
    skybox f5s
    quick one, can you use the loop back like on a sky box to watch on another tv at the same time or can you use the scart and wireless sender at the same time as the HDMI?
    Thanks Ahead.
  • P&D
    • May 2010
    • 2686
    Yes mate you can but you my need a signal fix for the F5s box
    do a search there loads of info about this
    Sorry thought you ment the original Sly box
    • Hadron
      • Nov 2012
      • 2102
      Thanks Ahead.
      The LOOP output isn't the same as the RF output on a Sky+ box. The LOOP output just routes the signal from the LNB input back out again. You cannot connect it straight to a TV (unless it has it's own Freesat tuner).
      Yes. You can use a video sender from the scart at the same time as the HDMI.
      P&D...the no signal fix is for when you are using 2 satellite boxes on 1 LNB. I think dojopros wants to use 1 skybox with 2 TV's.
      • dojopros
        • Nov 2012
        • 4
        thanks alot for the info!
