help with my openbox s6000hd
  • celeron
    • Jan 2014
    I am from Spain ... greetings to all .... I have a clone openbox s8000hd blocked with red light.
    not respond to anything .. only red LED lights ..
    I can not find information to flash and reinstall the image through null modem cable
    i have all cables but I do not know which files or programs using.
    I urge anyone can help me and send me information on what steps should I take.
    many thanks
  • P&D
    • 2686
    the palce is here Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
    If i remember right with red light means hardware problem i think
    • DW190
      • May 2012
      • 1263
      many thanks
      You would be better seeking advice from the Enigma 2 section as this is a Linux E2 clone of the VU Solo.
      • DW190
        • May 2012
        • 1263
        With the S6000HD the red light will turn blue when the image is loaded via usb.
        • P&D
          • 2686
          Thats why i love this forum you learn something new everyday
          so many intelligent members its great
          • mahrkpat
            • Jun 2012
            • 510
            ​The openbox s6000 is a vu solo clone and recovery is same as installing new image here is a tutorial I did on another forum:
            How to load new images to Openbox 6000 HD
            What you need:
            1.Download the image of your choice eg openpli, vix, blackhole etc..
            2.A USB stick formatted to FAT32
            Method:
            1.Open the rar/zipped folder that you downloaded (some people forget)
            2.You will see vuplus folder move it completely to USB stick
            3.Power off your box then plug in USB stick in to the USB port of your box
            4.Power on your box and wait your image will be updated (about 1 to 3 mins)
            5.Pinky light on front of box means updating image
            6.After 40 to 50 secs light will go red meaning formatting flash
            7.Light goes pinky again meaning writing to flash
            8.Once complete you will see flashing blue light
            9.You have finished power Off box remove USB stick
            You can switch power on your box now with your new installed image
            • DW190
              • May 2012
              • 1263
              What you need:
              Method:
              e
              Unreadable if using Original/Default Style interface
              • mahrkpat
                • Jun 2012
                • 510
                Thanks DW190 I've corrected it, I use darkcore default to bright for my tired eyes.
                • DW190
                  • May 2012
                  • 1263
                  here you go done mine so we can all see it twice now.
                  • celeron
                    • Jan 2014
                    nothing works
                    tuto to retrieve openbox does not work...is blocked with red LED and not respond to anything...possible with jtag ..????
                    • DW190
                      • May 2012
                      • 1263
                      nothing works
                      Have you read the thread.
                      The box you have is a Linux E2 receiver and does not work the same way as other Openbox's.
                      You need to upload an E2 image via the usb.
                      • Hadron
                        • 2102
                        They have both gone invisible again!
                        I notice both posts were "Last edited by digicon; Today at 09:21 AM." Did that have something to do with it?
                        • celeron
                          • Jan 2014
                          USB is not working
                          I put clear.....completely blocked..........turn on with red Light...nothing from usb...
                          thanks a lot
                          • DW190
                            • May 2012
                            • 1263
                            At least the threads not been closed, just unreadable.
                              I have tried to adjust the font colour so its easy to read for other members as i use the Dark skin i chose the white font have now changed to a more grey appearance
                              Hope you can see it now
