Hi,
Skybox has released a new software to fix the issue of the box failing to record while in standby. This is the official software which can also be downloaded from the official Skybox website and it is for the F5S and the F3s only. This post has been updated because a newer version of the software was released 2 days later on the 22/01/14 and the older software withdrawn. The top attachment is the new software while the bottom one contains the latest Skybox PICON files ( 24/12/13 ) which adds a channel ident image to the Channel info display bar and the Epg.
Skybox release notes state:
Any upgrade is done at the user's own risk but here's a short tutorial.
As always, first back up your original files before performing a software update. Using a USB stick that has been formatted to FAT32, enter the " Dump By USB " menu of your Skybox and first select the Image file ( which is your software backup ) and dump to the usb. Then change the image setting to miscellaneous files and select TP_PROG.dbs ( your channel list ) and CCcam.cfg ( your gift provider ) and dump these also. Make sure that you place a tick in each file you are dumping to usb by either selecting OK or the yellow button on your remote. Copy these files to a safe place on your PC. To upgrade, download the new software and extract it using the appropriate programme e.g. Winrar etc., then copy it to your usb stick. Once inserted, navigate to the " Upgrade By USB " menu option, select the image file, making sure it is ticked, do not alter any other settings and select upgrade. Wait for the upgrade process to finish and the box should reboot. If it does not reboot do it manually by powering off then on using the remote control. Then extract the PICON file and place the relevant .ics file for your satellite e.g. 0282E directly onto your USB or hard drive. Once this has been done using your remote control check and navigate through the relevant menus of your Skybox to ensure that the " Epg and Time Setting " is set to the default setting of " Internet ", the " XML TV Epg Setting " is set to " Automatic " ( you may prefer to do a manual download by pressing the red button for your first epg download ) and the " PICON view " setting is set to " On ".
- 1.Fix bug:Timer not work in standby mode.
2.Add descriptor for timer event.
Enjoy!- Regards,
- bigade1.
