no idea what happened ive tried everything !!
  • lynsey0609
    • Jan 2014
    hey u guys !!
    it could be possible that this is easy to fix and ive overlooked the easiest solution but im sure ive tried everything !!
    I was updating my channels from ajsat as i always have but this time its gone to pot !!
    i lost all my channels i can only get islam news channels, ive tried going back to my original back up channels and that hasnt worked. i checked all leads internet etc but nothing there and the dish hasnt been touched.
    so i done a satellite search got over 3000 channels but most of them are foreign or scrambled and ive just realised that i only have astra and hotbabe for searching channels where has my sky UK gone ???? ive tried both of these astra seems to give the best results on channels but their all over the place ive tried to group them in uk to get them in some sort of order but honestly its ridiculous how they are set at the min and searching through 3000 channels to move them about is just ridiculous !!!
    any help would be greatly appreciated as im about ready to launch the box !!
    thanks in advance
    linzi
  • wally6529
    • May 2013
    • 34
    Originally posted by lynsey0609
    hey u guys !!
    thanks in advance
    linzi
    Unzip AJ's List XX-XX-XX.zip with a program such as winrar & place the TP_PROG.DBS file onto the root of your USB drive.
    In the Openbox menu delete your current channel list by going to the "Edit Channel" tab & selecting "Delete All".
    Staying in the menu navigate to the "Tools" tab then "Upgrade by USB", change the upgrade mode from "Image File" to "Misc Files" then "Select & Upgrade" & select "TP_PROG.DBS" then press yellow, if all done correctly it should begin to upgrade.
    Once the upgrade has completed restart your box & voil?!Make sure you switch off the box at mains or press and hold standby until it reboots, try both, hope this helps
    • Hadron
      • 2102
      I'm puzzle as to why you say you are getting over 3000 channels & most of them are foreign?
      There are a few foreign channels on 28.2e, but not many.
      If you do as wally6529 says, then your channels should be back in order. Doing a blind or accurate scan without a channel list already installed will generate an unordered list.
      • lynsey0609
        • Jan 2014
        huge thankyou i have come home on my lunch to try again an hey presto minus the stress it worked thanks again guys !!
        just one last quick question theres some channels with low signal or scrambled is there any easier way to move channels with stronger signals to replace the not so good ones ?
        mum of 3 and in full time work its so time consuming
        x
