no signal on half channels when using wifi??
  • singh1234
    • Aug 2009
    • 156
    hope somebody knws what can be problem,i hav skybox f3s and am picking most channels but most movies channels are showing as no signal,what can be problem,im using thru wifi dongle
  • P&D
    • 2686
    More than likely answered your own question....last 2 words is your problem
    use a cable or homeplugs
    • singh1234
      • Aug 2009
      • 156
      is that what u think is the problem then? does the dongle give u no signal on channels tho?
      • P&D
        • 2686
        Hi sorry misread your question
        No signal ...means normally the dish or cable or tuner
        but could be channel list out of date (when was it last updated)
        Has it always been like this ???
        or has it gone like this since you have done something
        updated firmware /channel list
        • singh1234
          • Aug 2009
          • 156
          its a new box got off guy other day,was working fine at my house,when gave to mate half channels well most of movies shows as no signal when using thru wifi
          • comp07974
            • Jan 2014
            • 31
            It may be many contributors, obviously when you use wifi you are operating at half duplex. Can your friend get onto his home wifi box and run a ping test from his router to his skybox? the avg trip shoudl be no less than 50ms. First thing to try tho is directly connecting the box to the router for a full duplex connection.
            • singh1234
              • Aug 2009
              • 156
              how do u do a ping test as u say?the router is in other rrom,also sports walks just sum of movies show as no signal
              • DW190
                • May 2012
                • 1263
                If its showing "No Signal" its nowt to do with you network.
                Anything to do with network would show as scrambled.
                Try your youtube and see it the coloured disc spins when it loading
                • comp07974
                  • Jan 2014
                  • 31
                  Cheers DW190 , im new to this my self so trying to add some of my networking knowledge to the fray. So when i get scrambled it is a network problem then?
                  • comp07974
                    • Jan 2014
                    • 31
                    And not a problem with my ****
                    • singh1234
                      • Aug 2009
                      • 156
                      thanks dw190, my sports channels work but not most the movies,what cud be the problem
                      • DW190
                        • May 2012
                        • 1263
                        Put into simple terms
                        "Scrambled" = Network problem or anything that travels through the network to the box.
                        That's all you'll get on that subject.
                        No Signal = No signal getting through to box, be it dish, lnb, cabling, tuner or anything associated with the travel of the signal from the bird in the sky to the box.
                        • singh1234
                          • Aug 2009
                          • 156
                          well what u reckon cud be the problem,i have checked the box at my own house and all channels are working fine with and withous wifi usb,my router is right by my box,in friends house it is in another room? its picks sports channels but some movies shows as no signal?
                          • Partymad09
                            • 76
                            come out off ur fab and do a new channel search and see if it well work out there if so you need to update
                            • singh1234
                              • Aug 2009
                              • 156
                              @partymad09 what do I update with then mate? like I say it works fine at my house with or without the wifi usb,but at friends house shows as no signal?what cud it be? whats a fab sorry?
