SKYBOX F5S YOU**** FREEZING
  • Jackirwin
    • Jul 2013
    • 17
    hi guys this has been happening for some time now on both my f5 and f5s boxes they are up to date with newest firmwares but everytime I play something its like it always playing a few seconds then buffering then playing another few seconds ive tried using wireless and homeplugs its not my connection as I have 80 meg and youtube plays everything without a hitch im just wondering does anyone else have this problem
    Have you tried the Latest Firmware that was released a couple of days ago to see if that has a fix for the problem if not maybe trying an older firmware may work
    • Jackirwin
      • Jul 2013
      • 17
      hi mate thanks for your reply as I said yes my firmwares are always kept up to date I just maybe thought others would have the same problem because it always worked well before the last few firmwares but if I go back I lose my EPG
      • DW190
        • May 2012
        • 1263
        I don't have any of the s series but from what you are saying it was ok before you put the epg firmware on. If that's the case, what type of usb drive are you using?
        I have noticed in the past that some types of drive used to have an affect when viewing if the settings were set for catch up.
        • lincsat
          • 1228
          If using a USB stick for timeslip, that will be your problem. Most are not fast enough to record and playback HD channels on the fly.
          • Jackirwin
            • Jul 2013
            • 17
            no you don't get it I mean the actual you**** app itself without using usb or even a line as long as your box has internet it should work mines works but only plays the stuff then keeps freezing and playing another bit my youtube app works 100% so it has to be the app itself, and I have 80 megs connection and using homeplugs and even tried wireless but still the same
              I am afraid you hit the nail on the head as you say it works fine in previous firmwares but on the newer ones it does not, its a case of when new features are added in firmwares sometimes other things get broken which appears to be the case here.
              you have to ask yourself which is more important the 7 day EPG or the You**** app and falsh the firmware accordingly and then wait maybe for the software writers to fix the problem if it does get fixed at all.
              • tropic
                • Jan 2014
                change the ...........file
                it works for me
                • Jackirwin
                  • Jul 2013
                  • 17
                  just bought a skybox a3 and all apps and everything works properly so it was definatly the skybox firmware I thought other people might have noticed this
                  • revojack
                    • Jan 2014
                    • 17
                    Apparently i have been told that wireless is rubbish.
                    I use a home plug and it does scramble every so often
                    I have been told to take a network cable straight fm the router to the box for best results
                    hope this helps
