recover help
  • sammym321
    • 80
    recover help
    hi can any one help is there anyway i can recover a skybox s12 box becoz theres no rs232 conncet on the back of the box
  • DW190
    • May 2012
    • 1263
    Is this the box that has a four pin connection?
    • sammym321
      • 80
      hi thanks DW190 for your replz yrs it is mate
      • DW190
        • May 2012
        • 1263
        You need something from this lot.
        rs232 to ttl converter | eBay
        • sammym321
          • 80
          hi again will have to open the box to fit it rs232 ttl conveter im all new to sky game
          • vodka25
            • 21
            Put a post with a rough guide to area you are in mate im sure someone near you could help
            • DW190
              • May 2012
              • 1263
              No need to open the box. It has a four pin on the back and some of the USB to ttl have four females. I'm not sure of which wire goes to which pin but a google will find it.
              • sammym321
                • 80
                hi dus anyone know what color go's to what pin when im useing rs232 to ttl converter on my skybox s12 ?
                • slugworth
                  • Nov 2011
                  • 1064
                  no need for the converter,the 4 pins are rs232 and not ttl.
                  you need a 4pin converter to 9pin.
                  use an old pc cdrom 4pin audio cable
                  • sammym321
                    • 80
                    hi will this work mate
                    • sammym321
                      • 80
                      hi dus anyone know if i can use's one of theres rs232 to ttl converter
                      on a skybox s12 ?
                      • Hadron
                        • Nov 2012
                        • 2102
                        I would give up looking at ttl converters, as you won't find what you need.
                        You will need to make your own. If you haven't got an old connector from a pc you can use, then the connectors (with wires attached) can be found on Ebay. They are JST-XH connectors and are used in RC models:-
                        Lipo Balance Lead for repairing battery pack 3s JST-XH male 3-cell, 11.1V, 22AWG | eBay
                        You will also need a 9 pin (male) sub D-type connector.
                        slugworth has supplied the connection diagram.
                        • sammym321
                          • 80
                          HI HADRON THANKS FOR YOUR REPLY I WOS THINKING OF BUYING ONE OF THEM
                          WORK DO U THINK
                          • DeejayAJ
                            • Feb 2012
                            • 402
                            ^ I have one of those cables and it works fine.
                            • sammym321
                              • 80
                              HI DEEJAYAJ THANKS FOR YOUR REPLY I WILL ORDER ONE NOW MATE
