2 F5s Skyboxes in 2 rooms.. multiroom?
  • Dom29
    • Jan 2014
    • 12
    Hi all . ive just got myself an f5s box , bought a "gift" for it and it works fine , i want to put one upstairs also , ive tried splitting the cable inside the house using 2 splitters for each input but when one works the other doesnt (sky hd box and f5s box) and i wondered will i be able to go and run a cable from the dish outside or will I need a new dish ?? dont really understand thanks!
    each of your receivers should have an independant feed from the dish itself, as you already have an official HD box then you should at least have a Quad LNB on your dish (standard practice) which will leave 2 feeds left for you to feed the 2 x F5's
    • Dom29
      • Jan 2014
      • 12
      Thanks for the reply . i currently only have 1 sky hd box can i link up to the dish with 2nd feed?
      • mark8393
        • 2305
        Yes you can mate.
        • DW190
          • May 2012
          • 1263
          Originally posted by mark8393
          Yes you can mate.
          As long as its got a multi lnb.
          • mark8393
            • 2305
            He did say second feed. Most newer sky installed dishes have quad lnbs
            • Dom29
              • Jan 2014
              • 12
              thanks thats all i needed to know dish was installed around 18 month ago so surely should be one of the more modern ones.
                Dont Worry mate you have an Official HD receiver from $ly which requires 2 feeds so you will 100% have a Quad LNB on the end of the dish
                • Nobby Nutz
                  • Apr 2012
                  • 191
                  You may have Horizontal and Vertical Polarisation issues on your F5S where certain channels will not appear. Or come up with "No Signal". It may or may not happen just to make you aware. If it does search "No Signal Fix" on here or on Fleabay.
                  • bobhope1
                    • Nov 2010
                    • 85
                    If you are not bothered about watching the same program in a different room, i.e like me only watch one TV at a time you can buy the triax tv link kit
                    I currently have 3 TV's working from one box, all remotely controlled the same box via magic eye.
                    Its only me and the missus that watch TV, so it doesnt matter that we cant watch different channels in different rooms.Unless i want to watch the footie, in which case its tough shit
                    • MyB5
                      • 49
                      So, is it possible with normal homesharing through lan, using CCcam as server? Sharing my own card from main Skybox receiver to another in childrens room? In other words...anyone succeeded with CCcam acting as a server on a Skybox?
                      Vu+ Duo-BH 2.0.9,1
                      CloudIbox II+
                      DM600PVR & DM500
                      Skybox F5 & F5s
                      Oscam 9533 & CCcam 2.2.1
                      0.8/ 4.8/ 7.0/ 13.0/ 16.0/ 19.2/ 23,5/ 28,2
                      Scandinavian
                        @MyB5
                        Just a heads up you have been a member long enough and should know the forum rules by now no card share discussion end of: http://www.digital-kaos.co.uk/forums...rules-2/#post2
                        Discussions about cardsharing are not allowed, including, but not limited to, cccam, gbox, mbox, etc.
