HELP OPENBOX S10 Deleted all my channels how do i get them back??
  • hkoranteng
    • 4
    I turned on my openbox and my channels where not working all saying scrambled. I got the latest channel list being AJ's Openbox/Skybox List 11-1-14 but still the channels where scrambled.So I deleted all the channels please how can I get the channels back do i need the latest firmware?Thankyou
  • mtv1
    The Stig PT
    • 4413
    check your gift put the chanel list back in and check your network config
    be careful what you ask as no cs talk is allowed on here
    • sexysam
      • Oct 2008
      • 209
      Before you start you will need a USB stick and need Winzip or Winrar install on your PC
      Go to this website
      Once there, go to the section
      Channel List TP PROG
      Download this and save onto a USB stick
      Now plug the stick in the F box
      First of all go to the Menu Panel and into the Edit Chanel
      Click on Delete All channels ( and delete)
      Next go Tools
      Click on Upgrade by USB
      Where it says Upgrade Mode at top press sideways on the remote till you see Misc file
      press start (OK button)
      then highlight TP_prog/press ok it should put a green tick at the side
      press the yellow button on the remote wait till the box does its thing
      Once done press exit button on remote ( it should save settings)
      Exit it completely and then reboot the box.(make sure you do this otherwise it will not be saved)
      Hopefully all channels will be back.
      If this is to hard for you to do, then just ignore all above and go into Installation in menu button and press Single satellite search and press scan…..this will scan the whole satellite and store channels…….but these wont be in favourites but in ALL…( however this will also download all adult channels as well
      Last edited by digicon; 26 January, 2014, 23:48. Reason: Do not post this link again Please
      • Hadron
        • 2102
        If all of your $ channels were showing scrambled, then it has nothing to do with the channel list. It also has nothing to do with the firmware (besides, the latest firmware for the S10 will be a couple of years old by now!).
        It will be down to either your internet connection, or your "gift".
        We can help with the first, but not the second.
