No Signal Fix Cable
  • wardyuk1
    • Oct 2013
    • 5
    No Signal Fix Cable
    Hi, does anyone know how to make one of "no signal fix" cables? I know that there is a resistor or something like that in the middle of the cabling.
  • bobhope1
    • Nov 2010
    • 85
    Just buy on off ebay, there only about a skin diver delivered
    why do you need one?
    • cactikid
      • 12017
      more than likely his lnb dont suit the skybox,very very common fault and if using the fix and moving box it might short out and blow the box.
      • Hadron
        • 2102
        It's just 1 rectifier diode (such as a 1N4001, 1N4002 etc.). The diode is polarised with a white band, so has to be connected the right way round.
        Have a look here:-
        • wardyuk1
          • Oct 2013
          • 5
          Thanks for the replies. I don't need one. I just like to know how things are made & how they work. Thanks for the replies once again
          • Nobby Nutz
            • Apr 2012
            • 191
            If you come across the problem best fix is a decent LNB
            • cactikid
              • 12017
              or buy a better satbox that uses proper internal parts.
