I've d/l the latest channel list off aj's and installed it,but the genre's on the favourites don't tally with the channels. i.e. kids shows movies,movies shows sports etc.Am i doing something wrong?I've got the latest firmware installed as well.still learning folks,all help gladly welcome.
another niggle! sorry.
Tags: None
Thanks to sattv5 for the mini guide:
My Favourites are all wrong since I loaded your list how do i fix them ?
The way to get The favourites under the correct headings is to load the default Database:
On the remote select Menu > Factory Settings > Select Yes > Then Press Blue (Don't make any choices at the menu)
The screen will flash black and you will be back at the menu. If you check your favourites now they should all be in the correct order
