Randomly missing channels (using AJ's list)
  • KevHal
    • Jan 2014
    • 5
    Hi, very strange problem. I keep missing random channels chich give me a signal of only 5%. This morning ive lost the BBC ONE HD and BBC TWO HD. No Signal. Also lost Sky Sports 3 HD. I have regular Sky and checked that BBC ONE HD etc work fine and they do. Go back to the Skybox and they don't. If I don't use AJ's list and manually find BBC ONE HD after a satellite scan and works fine. I checked BBC TWO HD on Lyngsat and it looks correct.
    Anyone getting randam channels getting no signal. Every other channel gets arouned 76% signal quality. Also lost Sky Sports 3 HD
    Not sure if its an issue with AJ's list of the way I have set up my skybox.
  • redralph
    • 171
    Is it the V frequencies missing, if so you need the No Signal Fix, ?5 fleebay.
    • Hadron
      • 2102
      Did you check the frequency of BBC1 HD before & after you did a scan? Was it the same. Both BBC1 & 2 HD working OK here on AJ's latest list (11/1/14) on 10847V.
      You say that you also have a subbed Sky box. Was that box also switched on when you noticed that some of your channels were missing? If so try turning it off & check again. As redralph says, you may need the "no signal fix" if so.
      • KevHal
        • Jan 2014
        • 5
        Cheers for the quick replies guys, you were right, as soon as I turned my Sky digital box off, bbc one re-appeared. Strange, hadn't realised it would only affect certain channels. Happy again.
