Channel noob question
  • hkphooey
    • Apr 2010
    • 232
    Guy's just got my box was wondering why I can't get the channels up same as sky if I put the numbers in manually
    Thanks for any help
  • redralph
    • 171
    You need Sattv5 channel list from the sticky above your post
    • DigitalVandal
      • Jan 2014
      • 138
      If you're like me, you'll download that because you think it's easier then after a day or 2 realise it's not and go back to AJ's list.
      • hkphooey
        • Apr 2010
        • 232
        Cheers guys....Sorry for all the noobie questions just didn't think these boxes were so whats the word????? frustrating!!!!
        • hkphooey
          • Apr 2010
          • 232
          Mate is that what's on it out of the box???
          • mahrkpat
            • Jun 2012
            • 510
            No mate the list you get is probably out of date, both Aj and satv5 do a lot of hard work in creating these list and keeping them up to date and it is a matter of preference of which you will end up using regularly each person is different.
            • amjadhussain
              • Apr 2011
              • 92
              Haha I'm curious as to why you felt this way?
              I've been living elsewhere for the last year and always used AJ list, which is good and fine for me but now buying a F3 for my father, and was thinking maybe using the proper sly channel list (forgot the guys name who does it) would be better for him, and wouldnt make a difference for me.
              Im guessing it is because these boxes are a bit laggy (not as smooth as genuine sly boxes) hence it could get a bit frustrating?
              • DigitalVandal
                • Jan 2014
                • 138
                The favourites list is a lot easier way of navigating the channels, I've tried both and there are far less steps to using AJ's list. Unless you know the channel numbers off the top of your head.
                • hkphooey
                  • Apr 2010
                  • 232
                  The favourites list is a lot easier way of navigating the channels, I've tried both and there is far less steps to using AJ's list. Unless you know the channel numbers off the top of your head.
                  Yes mate i do that exact same thing... i use a android app for the listings. Just wanted to know if i update the channels list will it add extra/missing channel's pehaps???
                  • amjadhussain
                    • Apr 2011
                    • 92
                    Yes. Thats why AJ updates his list regularly and we all update it regularly.
                    Channels usually change frequencys (transponders i think it is called). So one day your SkyOne may not work. If you do a scan you wil end up with a few SkyOnes of which 1+ will work of course. But if u wanna add this to ur existing list and remove the old one it is so tedious.
                    so updating channel lists is very good. Get rid of all that doesnt work, and left with everything that does work.
                    • hkphooey
                      • Apr 2010
                      • 232
                      Cheers bud i am getting there now, just updated with AJ's latest list and all seems great ....
