Sky box F5s
  • twinnie2
    • 26
    Sky box F5s
    Hi I'm a newbie just got the F5s box put upgrade on box and it keeps rebooting, any ideas on how i can stop it rebooting so that i can get into the menu.
    thanks mark
  • amjadhussain
    • Apr 2011
    • 92
    Sorry I cant help you but im curious does a F5s have a USB socket at front or only at the back of the box?
    • P&D
      • 2686
      thanks mark
      Remove the sat cable see if it stops re-booting if it still does
      Sounds like you have loaded the wrong firmware....did you make a backup of the box before messing with it ???
      you now need this link..Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
      Can i ask why your messing with the firmware ???? if the box was working which i guess it was if new....why you messing with it ??
      and now you have to learn a new trick to fix it....
      • twinnie2
        • 26
        No the USB port is at the back.
        • twinnie2
          • 26
          Sent the box to be checked found out its a Clone, getting returned to the EBay seller.
