NO CH on skybox F5s
  • Awalla
    • Feb 2014
    NO CH on skybox F5s
    I need help to reinstall channels on skybox F5s
  • Nobby Nutz
    • Apr 2012
    • 191
    See stickies for AJ's Channel List or Sattv5 Channel List both have instructions (It helps if you read or Search for things) and don't forget to hit the "Thanks" button on whichever you choose for all the superb work they do.
    • alienkargo
      • Jan 2014
      • 63
      Unzip AJ's List XX-XX-XX.zip with a program such as winrar & place the TP_PROG.DBS file onto the root of your USB drive.
      In the Openbox menu delete your current channel list by going to the "Edit Channel" tab & selecting "Delete All".
      Staying in the menu navigate to the "Tools" tab then "Upgrade by USB", change the upgrade mode from "Image File" to "Misc Files" then "Select & Upgrade" & select "TP_PROG.DBS" then press yellow, if all done correctly it should begin to upgrade.
      Once the upgrade has completed restart your box & voil?!
      taken from the sticky so you didn't need to search.
      • Nobby Nutz
        • Apr 2012
        • 191
        Still got to go to the stickie to get the file or are you going to put that here as well ?
        • DigitalVandal
          • Jan 2014
          • 138
          he's only trying to help
          • P&D
            • 2686
            • alienkargo
              • Jan 2014
              • 63
              He asked for help not where to find the file.What's the point of this forum if no-one helps?
                It Helps to do a Search first as everything including Guides for the Open/Skybox can be found in the Red Stickies, which will get you up and running in minutes instead of asking a question that sometimes either A. no one is around to answer or B. its been asked that many times members are sick of answering them.
                This is not a Question of being Unhelpful far from the truth if common sense prevailed for most people
                • Nobby Nutz
                  • Apr 2012
                  • 191
                  "See stickies for AJ's Channel List or Sattv5 Channel List both have instructions" If this isn't helping I don't know what is
