Circuit board take a look.
  • sailsy
    • Mar 2012
    • 145
    Hi guys over the years i have seen boxes with a wired loop on circuit boards!
    I have never took much notice and always presumed they must be cloned boxes but they have always worked!
    On this particular box one of the wires has come away and im not sure where to reconnect it to does anyone have an idea please?1.jpg
  • Nobby Nutz
    • Apr 2012
    • 191
    That's just a Mod Wire where a design fault on the board etching has been found and a "Mod" wire added.
    Is it working without it ?
    An old adage if it ain't broke don't fix it
    • sailsy
      • Mar 2012
      • 145
      No it ain't working tried flashing first the flash goes well and completes but still does not display anything then I noticed this loose wire?
      • Nobby Nutz
        • Apr 2012
        • 191
        Need to look for excess solder within the radius of Wire looks like there is some on 2nd Pin up on RHS of Chip but could be mistaken.
        What box is it as other members may be able to open there's up and advise.
        • alessioblaupunkt
          • 943
          sail please take a crystal clear picture of the entire board so I can help you locate where the wire was attached.
          Use an hd camera, no phone camera.
          • sailsy
            • Mar 2012
            • 145
            DSCF0763.JPGhere you go
            • slugworth
              • Nov 2011
              • 1064
              without knowing the brand/model of receiver,just a guess.
              looks like some sort of write enable or protect on an eeprom
              • Hadron
                • 2102
                From the amount of solder on the pin, it looks like it goes to pin 2 of the chip (second pin in from the top right).
                What Openbox/Skybox model is it?
                • sailsy
                  • Mar 2012
                  • 145
                  It's a s10 I've seen this before on some boards but never took much notice!
                  • slugworth
                    • Nov 2011
                    • 1064
                    that is the protection ic and it makes no sense to go to those pins.
                    pins 5 and 6 on the other side are the i2c bus
                    would be interesting to know what the mod did,I have one that has a corrupt chip.
                    • slugworth
                      • Nov 2011
                      • 1064
                      senseless
                      pins 1-3 aren't even used,pin 4 is gnd
                      • sailsy
                        • Mar 2012
                        • 145
                        I have definitely seen this on two boards I've had I think me dad or sister has them I'll have to look at them when I see them next
                        Was a lot smaller loop may not have even gone to there!
                        • slugworth
                          • Nov 2011
                          • 1064
                          on a regular eeprom like a 24lc16 (s10 clone?)pins 1,2,3 are used as the chip address and are usually tied to ground.
                          It may be a regular eeprom with a trace cut on the bottom and jumper to pin 2 for some reason.
                          Other brand/models may have a jumper to disable the chip.
                          • slugworth
                            • Nov 2011
                            • 1064
                            after loading firmware the receiver would boot to -- with a bad chip unless you were using anonymousx firmware
                            • sailsy
                              • Mar 2012
                              • 145
                              I had that on there last night when I held it by hand to first pin top right
