I have a 6 month old F5 which has developed a load up problem (looping) gets to 100% then back to re-load. After spending 6 days and re-flashing my skybox time and time again with different .abs files, all to no avail, faults with only loading to 93% or 97% hanging on 98% (this is a programming fault not the box), reading loads of posts about mismatched files..... THIS IS WHAT I HAVE DISCOVERED...... If you haven't re-flashed your box...... DON'T...... KEEP YOUR ORIGINAL SOFTWARE THE BOX IS NOT BRICKED OR DEAD. However there is fault with the box that re-flashing will not cure. The problem is the satellite coax has a voltage running through it that causes a short in the box and stops it from loading. All you have to do is remove the coax connection from the box, switch on the box let it load it might take a few attempts to load then re-connect the coax to the box. Hey presto everything should work until you turn off the box or it freezes, just disconnect the coax again let it load up and re-attach. This is not a firmware problem it is a manufacturing fault.
If you have re-flashed the box and are having problems go to SkyBox | SkyBox download the official .abs file for your machine but remember you will still have to disconnect the coax cable before it will reload.
HOPE THIS HELPS.
HOPE THIS HELPS.
