Skybox help?
  • Santz92
    • Feb 2014
    • 8
    Skybox help?
    Hey !
    New to this so please forgive me if I ask a stupid question.
    do I need a satellite to view channels on my skybox f5? Because I don't have a satellite in my house...all I have is a sky box with only the free view channels and on my roof I have an antenna for the picture quality.
    thanks in advance
  • P&D
    • May 2010
    • 2686
    If you consider this is a satellite forum you have asked the question in the easy answer = yes
    • Santz92
      • Feb 2014
      • 8
      Thanks! how can I go about getting myself a satellite ?
      • DW190
        • May 2012
        • 1263
        About ?25.00 on the bay with all the fittings you need.
        • Nobby Nutz
          • Apr 2012
          • 191
          Think we may have mis-interpreted your question.
          Can you clarify you have a Skybox F5 and you are receiving Free To Air Channels is this correct ?
          • Santz92
            • Feb 2014
            • 8
            Sorry no, I have a normal standard sky tv box showing free view. I have just bought a skybox f5 waiting to be delivered. I have no satellite dish But I have an antenna on roof.
            In regards to me buying and installing a satellite.... Which direction would I need it to look at?
            • redralph
              • 171
              Astra 28.2
              • Nobby Nutz
                • Apr 2012
                • 191
                You maybe better getting someone to install it for you
                I would try 28.2 East
                • Hadron
                  • Nov 2012
                  • 2102
                  I still don't understand.
                  If you are watching channels through a "normal standard" Sky box, then you must already have a satellite dish.
                  If you are using a terrestrial aerial, then it won't work with a Sky box.
                  • Santz92
                    • Feb 2014
                    • 8
                    I have a normal standard sky box with the free to air channels.
                    • P&D
                      • May 2010
                      • 2686
                      Is this the box you have ????
                      If so you have a dish on the roof but most prob a shared one
                      so if you get a openbox/skybox f5 then yes it will work
                      but you may have a problem with the signal & need the signal boost fix
                      Also you need more than just the box & the channel list to get your channels
                      But this we cannot help with
                      • Santz92
                        • Feb 2014
                        • 8
                        Thanks for response, that is not the one I have. I have the original standard sky box (link is below with pic)
                        • boobishabang
                          • Nov 2011
                          • 43
                          Any Sly box such as that in the picture would need an Lnb\dish feed to work so you should be fine with the F5
                          • DW190
                            • May 2012
                            • 1263
                            So you have a dishand if that box is working the dish will be fine for the F5
                            • Santz92
                              • Feb 2014
                              • 8
                              Just spoke to a sky advisor he said to me...
                              'Then there is a free to air communal dish from where you get a dish input cable running into your house which enables you to view the free to air channels.'
                              would the Skybox still work??
