firmware skybox F5s
  • shaun12345
    • Apr 2009
    • 17
    firmware skybox F5s
    regarding the firmware for the skybox F5s
    Is there a way to make a copy of the default firmware on the box and copy it to a usb drive in case anything goes wrong after flashing a different firmware.
    cheers
  • P&D
    • May 2010
    • 2686
    yes mate if its the same menu as the f3
    menu/dump to usb/save as image or by each file( i did it by each file saves everything including the special bit)
    • shaun12345
      • Apr 2009
      • 17
      thanks for the reply will try out your suggestion appreciate your help
      • ngabcs
        • Jan 2014
        I have a skybox 5S boxes, it has the latest firmware from ksybox.cc.
        I love this device because of its simplicity, but there are a few things ought to be improved:
        - When playing divx subtitles unfortunately not good ?UTF8?, bad of ????ő??? (hu lang) only "_"
        - Using a USB hub to your media player does not appear in both HDD: uda1, udb1
        - XMLEPG not automatically updated from the Internet, just by hand
        Together with more than 10 skybox F5S is used, we'd love to support the development of skybox F5S firmware.
        I really miss the DLNA or other network share for skybox Mediacenter.
        Most of this is the answer: you have to take the linux dre@mbox with it makes the people you want, but it's a simple man too complicated.
        I hope it does not stick out of the box also during this phase.
