Best site for xml for epg?
  • dilzy2
    • Feb 2014
    • 26
    Whats the best site for xml for Skybox f5s as the built in satellite scanning only shows whats on once the channel loads.
  • Nobby Nutz
    • Apr 2012
    • 191
    Read this thread and all will be revealed if you have a Skybox F3S or F5S
    • dilzy2
      • Feb 2014
      • 26
      http://www.digital-kaos.co.uk/forums...1-14-a-395702/
      That has absolutely nothing to do with my question?
      • brizo
        • Feb 2014
        • 19
        It actually has everything to do with your question if you would take the time and do a little research
        • johnmil7
          • Oct 2013
          • 19
          Once you have installed the firmware suggested above you can switch your EPG settings to XML. Your box will then download the 7day EPG for you and you can look at what is on other channels without turning the channel over
          • dilzy2
            • Feb 2014
            • 26
            Thanks for your help but sorry for not being clear enough. I have the firmware that allows me to use XML however I cannot find any xmltv source that works
            • crude
              • Oct 2013
              • 34
              Dumb question but have you updated the EPG? The latest skybox firmware automatically points to the remote xml source for the EPG- all you need to do is update it every week (that is if you don't put the skybox in to standby where it will automatically update)
              • gongatots
                • Aug 2013
                • 8
                Pretty sound advice.
                The op sounds like he/she is a little confused so 5 mins reading that might calm them down a bit.
                • Nobby Nutz
                  • Apr 2012
                  • 191
                  As the thread gives instructions on setting up EPG on the F3S & F5S. I would have assumed it was a very relevant answer to your very ambiguous question.
                  And when you have Read It leave a "Thank You" to Bigade1 for taking the time to put the instructions together to assist people like you.
                  • johnmil7
                    • Oct 2013
                    • 19
                    On my box I went into the EPG/XML settings in the settings menu and changed the United Kingdom option to Auto Update and then pressed the red button on my remote to update the EPG. It takes about 10 minutes to update but that's it working. I never had to enter or select a source for the XML downloads
                    • alienkargo
                      • Jan 2014
                      • 63
                      anyone notice whether the auto update actually works?I turn my box off with the TV and update manually via the red button.The old man in law leaves his on all the time with all the same settings as mine,yet I still have to go round and update it manually, even though we both have auto update on.
                      • alienkargo
                        • Jan 2014
                        • 63
                        I seem to remember you posting a comment like this to me.No disrespect but If you were more clearer in the first place when posting links to other posts us newbies wouldn't need you to reply again!
                        • bbb_uk
                          • 429
                          From my experiences, I found the auto update is hit & miss. Sometimes it updates and sometimes I have to manually do it.
                          Personally, its still better than the basic now & next so I can live with it.
