installation problem
  • eggfoo17
    • Aug 2009
    • 40
    Hi all I have a quick question need some help I have just installed a satellite dish on the side of my house and run the coax down to my new box. When I connect im am getting no signal at all cant even pick up basic channels like bbc just says no signal. have bought a satellite signal detector and plugged into my box and moved the dish till it has full signal but I am still not getting a signal , the box is fine as I have tried it on my neighbours and works fine. any ideas or things I can do to sort it
    cheers
    eggfoo
  • DW190
    • May 2012
    • 1263
    cheers
    eggfoo
    If it works on a neighbours dish you will have to keep playing till it alligned to the sat.
    Stick it on BBC1. press the info button 3 times and keep trying till the bars go coloured..
    You could get a good idea of the line to point it here:
    [URL="http://www.dishpointer.com/"]Satellite Finder / Dish Alignment Calculator with Google Maps | DishPointer.com[/URL]
    • Hadron
      • 2102
      Yep. I suspect that your dish may be pointing at 19.2e instead of 28.2e. It's very easy to do.
      It may need a bit of a nudge eastwards.
      You could select 19.2e (Astra 1H/K/L) from the satelite list & doing a blind scan to verify if you are pointing at this satellite.
      • lescombes
        • Dec 2013
        • 13
        +1 with what Hadron said.... for me I have a flex feed LNB for 19.2 & 28 birds.... and 19.2 is my default for LNB 1 and the dish and 28 is LNB 2 offset by 9 degrees
        Try a scan on 19.2 ... if that is what you have nudge the dish...
