channel list for f5s in sky order?
  • tamgunner
    • 691
    hi guys had a few people asking if they can get a channel list that in the order of sly channel numbers ive downloaded channel editing software and loaded the list but have no idea how to make bbc1 channel 101 etc is there a list already made or a guide?
  • boobishabang
    • Nov 2011
    • 43
    There is a sticky on this very page with a Sly numbered Channel list, look at the sticky's at the top, 2nd from bottom (red writing)
      If only people would use the Forum Search Facility : http://www.digital-kaos.co.uk/forums...-f4-f5-354446/
      • tamgunner
        • 691
        well actually i found the sticky ur talking about i uploaded to the box and the channels where not the same as the sly channels!
          This was your initial question regarding creating a list with the $ly numbering system
          I never said load a channel list i pointed you towards a Guide written by sattv5 to create your own channel list from scratch
          • Hadron
            • 2102
            The sticky you need is the one by sattv5
            • tamgunner
              • 691
              tried that one to hadron unless im doing something wrong when i go onto 101 it gives me invalid channel or changes to uktv
              • bigade1
                • Oct 2013
                • 340
                Taken from Sattv5's first post in his sticky:
                When wanting to type in a channel e.g 101 or 401 why do i get "no such channel" ??
                Press the ok button, then press the red button then select All.
                Then when you come out of that press 101 or 401 and hey presto you should then get the full list of channels.
                • southpaw
                  • 2233
                  don't go uploading sticky guides to your box mate, it will inevitably balls it up
                  • tamgunner
                    • 691
                    whats the best way southpaw for channels then?
                    • Hadron
                      • 2102
                      tamgunner...did you try what bigade1 posted?
                      • tamgunner
                        • 691
                        i tried it but nothing happened!
                        • Hadron
                          • 2102
                          Not sure what you mean by "nothing happened"?
                          Just to make sure that your old channel list isn't still installed, are you deleting your channels before installing sattv5's channel list?
                          Are you still getting channels listed between channel numbers 1 and 100? If so, then the channel list hasn't installed properly.
                          • tamgunner
                            • 691
                            yea im putting on sattv5`s list on to a brand new box which doesnt have a channel list but the channel numbers are still between 1 and 100 when i goto upload the dbs file it says its ok after its finished i switch the box off and on push ok then try pushing the red button and nothing happens dont get anything popping up on screen to say select all when i exit the channels are between 1 and 100
                            • Hadron
                              • 2102
                              What do you get on screen when you push the OK button?
                              What channels are in positions 1 - 5?
