I am pritty much stuck in limbo.
purchased a skybox f5s, existing installation of skydish with quad lnb.
switch on. AJ's list bang 76% signal. all is happy with the world.
Until i wanted to watch more.
purchased a 1 meter dish off fleabay from system sat.
included
dish,lnb, L shape wall bracket, and the disceq 1.2 motor.
Turned out i would need a bigger bracket due to the location of where the satellite had to be to be in the line of sight for the satellite.
T and K bracket would be needed instead.( see pictures they paint the picture)
NOW THE PROBLEMS BEGIN.
got the dish mounted on the most perfect horizontal hole you can imagine know to man, checked with 3 meter spirit level.
using RG6 cable (brand new) all connections have been reterminated, twice.
trying to find either thor 0.8 west or 28.2e cannot even sniff higher the 45% signal
moving the satellite up, down, left, right on the mount even left an right on the motor
tryed the elevation up an down, basically the satellite has been in every direction and still no sign of the signal going over 45%
LETS START SWOPPING PARTS
unscrew the lnb from the motor signal drops to 37%, screw it back up 45%.
bought another brand new lnb (nothing)
replace cable going from lnb to motor (nothing)
throw skybox f5s out the window to see if there is a possible fix (very close too doing)
i have a dreambox dm7020 i can swop it with but since it is set up i dont want to throw it all out (newbie at dreamboxs)
KNOWN FACTS
the motor moves left an right from the skybox and the box will bring the motor back to 0%
tryed all 45 transponders on 28.2e still at 45%
no difference between horizontal transponders and vertical stays at 45%
the motor light is solid green
asoon as i plug the orginal sky dish back in, all of the 28.2e channels come back on
used satfinder app on iphone to check the line of sight at satellite, also elevation and the azimuth angle
tryed to find bbc world news on 0.8w forget the transponder number i was using now but i got it off lingsat
tryed to match the satellites angle up with an existing satellite which is 2 meters away from it
HELP
i have read the forum for anyone is my situation, cannot seem to find anyone as daft as me to get a 1meter motorised dish an be stupid enough to attach it too a skybox an think that it would work.
Has anyone used a skybox f5s to align there motorised dish to work ?
does the motor consume all the power, so there is no power going to the LNB ?
IF solved i promise to write a blog on how to install a motorised dish ONLY using a skybox (if possible)
included
KNOWN FACTS
HELP
