SKYBOX F5S - Changing channels by logging into IP address by either CMD propmt or App
This topic is closed.
  • indianflava
    • Aug 2009
    Hi...Does anybody know if it's possible to change the channels on the SKYBOX F5S by logging into the IP address by either CMD prompt (through a laptop,) or by using an Android App? Thanks
  • bigade1
    • Oct 2013
    • 340
    No offence but you could have made your post a bit more clearer. If you mean change the channels by updating the channel list then this can be done on your pc using the skybox lan tool which is available from the Skybox.cc website. If you mean change channels as in using your remote to switch from one viewing channel to another different viewing channel then I would doubt if you would be able to use it using an app or cmd.exe but do not know for certain.
    • indianflava
      • Aug 2009
      yes i meant switching channels (without using a remote control)
      • bigade1
        • Oct 2013
        • 340
        Ah . Well I don't know for sure if that would be possible but I would doubt it.
        • Nobby Nutz
          • Apr 2012
          • 191
          There's an App for that
          • katieb
            • Feb 2014
            • 63
            whats the app
            • southpaw
              • 2233
              There ain't no app for it for these cheap sky/open box, enigma 2 has apps for it
              • P&D
                • 2686
                and you can watch the box anywhere in the world with the app setup right & the router setup to forward the correct port
                Never miss the tv you want to watch.....soccer...rugby....Eastenders & Corrie (not for me but..)...i'll stick to the sports
                whatever sat or station its on ......you can still watch it on your phone (as meat say's( ishit)...(android)...laptop....tablet....anything that can connect to the internet....
                The point is buy an E2 box the worlds your oyster once you find out how to work it....many hours of reading will help ...believe me....once mastered or just a bit of knowledge...
                You will ask yourself why did i waste ?50 on the box i bought....
                Before you ask it's defo not plug & play for cheap tv....
                But in the long run its well supported & once you get the basic knowledge how to use the box...... HAPPY...TV
                • Nobby Nutz
                  • Apr 2012
                  • 191
                  Meant to be a joke !!!!
                  ?48.00 Box what do you expect
                  • katieb
                    • Feb 2014
                    • 63
                    ?43.50 now
