Skybox F5 ITV HD showing invalid program Help
  • rick5069
    • Mar 2014
    • 5
    Please help, I am new to all this but I have downloaded latest channel list and installed but still no ITV HD, I even tried manually inputting the PID ect but I don't really know what im doing. i know im not the only one this is happeing to as my friends is doing the same
    any help much appreciated
    Read this : http://www.digital-kaos.co.uk/forums...ml#post2244250
    and then download fixed list: http://www.digital-kaos.co.uk/forums...1/#post1980897
    • TomFCUM
      • Mar 2014
      • 18
      I had the same problem. I deleted all channels, did a fresh blind scan and then used sattv5's March 4th channel list. That has worked perfect for me, although it has been recommended to use AJ's new list from someone else on the forum. Gonna download it and see what the difference is today.
      Remember to do a backup before doing anything and you should be fine
      • rick5069
        • Mar 2014
        • 5
        thanks I did try this but it stayed the same
        • rick5069
          • Mar 2014
          • 5
          Thanks maybe that's where im going wrong as I didn't delete the channels, could you tell me how to back up before I do this
          • Nobby Nutz
            • Apr 2012
            • 191
            Plug in USB
            Menu
            Tools
            Dump by USB
            Image File *.ABS
            Start
            • rick5069
              • Mar 2014
              • 5
              thanks I will have a go and let you know if It works
              • Nobby Nutz
                • Apr 2012
                • 191
                You can also copy individual files when you get to Image File *.abs use the Left and Right arrows will bring up
                Misc Files
                Select Files Hit OK
                TP Prog.dbs (Channel List)
                CC????.cfg (Magic Piece)
                Are the impotant ones
                Hit Green Button to Add
                Yellow Button to Dump
                • bobhope1
                  • Nov 2010
                  • 85
                  There is still an issue with ITV HD, they dont show up on the EPG, so you never know whats on.
                  Best way around this, is to put it in your favourites,and then put a ITV SD channel in behind it, at least that way you can see whats on
                  • rick5069
                    • Mar 2014
                    • 5
                    Thanks NN that sorted it!!!
