Suddenly no signal
  • hkphooey
    • Apr 2010
    • 232
    #16
    Well checked this morning and channels are back!!!!!!!!!!!!!!!!!!!!!!!!!!!! thing is i have just upgraded my firmware thinking that was the issue put channels back on i think??? is it the F6 channel list from AJ i use please??? there are now no fav groups???? just says fav group 1 2 3 4 etc and not sure they have updated????
    Have i done something to rest this in the upgrade please??? i would like to get back to how it was before
    • mahrkpat
      • Jun 2012
      • 510
      #17
      F6/X5 ch will might /brick your box you need AJ's channel list at the top AJ's ch list
      For fav order take this advise from sattv5:
      The way to get The favourites under the correct headings is to load the default Database:
      On the remote select Menu > Factory Settings > Select Yes > Then Press Blue (Don't make any choices at the menu)
      The screen will flash black and you will be back at the menu. If you check your favourites now they should all be in the correct order.
      • hkphooey
        • Apr 2010
        • 232
        #18
        Lost signal again jesus christ what the hell is wrong with this thing
        • freakazoid789
          • Dec 2010
          • 89
          #19
          Same thing happened to me, for a few weeks now!!
          Works only with blind scan
          But not with ANY channel lists
          Help please too!??
          • hkphooey
            • Apr 2010
            • 232
            #20
            Guys mine i think was the connections i have gone to every connection and re fixed it from the sat dish right through to inside my house and through to the faceplate, just snipped backed and reconnected f connectors and its back for now fingers crossed....
            Thing is i have $ly plus so know hen the signal is fine from the dish as that is working fine.
            • tamgunner
              • 691
              #21
              ive got the same issue but its only on movies and music channels fta and sports etc is fine ive tried 3 different f5s channel lists and 3 different firmwares and nothing only thing it can be is the lnb if ur using a octo lnb from what ive read the f5 boxes struggle with it and u need an inline filter to fix it
