I have recently purchased an F3s from a reputable seller on Ebay. I bought some accompanying warrantry from another seller.I am running the system using the WIFI dongle and had no problems to start with. I upgraded the firmware to the latest on on SkyBox | SkyBox and began enjoying the limitless programming.Recently the box will sometimes randomly reboot itself for no apparant reason?any ideas?
SKYBOX F3S Randomly Crashing
Latest is not always the best if you had a good working box what was the need to upgrade firmware? Sometimes if a firmware has not been thoroughly tested then there may be a bug in it will get corrected in the next release. I would suggest you go back to the firmware you were using before. -
I have an F3S running on the 24/12/2013 firmware from the Skybox download solid as a rock only issue is with EPG not Auto Updating not that much of an issue though.Comment
