Blind Scan
  • skelfbsfb
    • Mar 2014
    • 38
    Blind Scan
    I have just started getting issues with my picture, sound so today I did a blind scan and Ive noticed alot of it is saying failed. These are mostly on V - V22500 Failed. Now Im not even getting BBC or movies but am able to see sports. Baffled as to why this is happening as it just started doing this.
  • Nobby Nutz
    • Apr 2012
    • 191
    Have you got a second box connected ?
    If so you may have the H&V LNB Polarisation problems on your box. "No Signal Fix"
    Just a thought or dish has moved perhaps.
    • skelfbsfb
      • Mar 2014
      • 38
      I have a sky box in living room and one upstair. Both of these have seperate feeds into the house. Im using a splitter on the one in living room and when I use skybox I turn sky off before use. As I have said Ive not had issue before and it just started to happed over the past rew days. It appears to be more with HD channels as I can get all sd channels but sometimes with a bit of freezing.
      • Nobby Nutz
        • Apr 2012
        • 191
        It's a case of isolating where the fault lies.
        I assume everything is all OK with your living room setup.
        Take a note of how many channels you get on the bedroom box via Blind Scan.
        Disconnect your bedroom box and connect it to the Living Room Coax feed do another Blind Scan don't need an Ethernet Connection for this and see how many Channels you get.
        1, If it's the same you have an issue with your box (You haven't specified what model the box is) either a Tuner or PSU issue.
        2, If you get more channels then you have either a Cable (water ingress, connectors or corrosion) fault or an LNB Outlet issue to your Bedroom connection.
